Compact CoreXY Build October 10, 2014 06:28PM |
Re: Compact CoreXY Build October 11, 2014 07:45PM |
Re: Compact CoreXY Build October 11, 2014 10:51PM |
Re: Compact CoreXY Build October 13, 2014 04:28PM |
Re: Compact CoreXY Build October 13, 2014 06:41PM |
Admin Registered: 13 years ago Posts: 3,096 |
Feign
That does look pretty awesome, but I wonder if you'll run into problems at that intersection. It looks like the belts are rubbing against each other. While the effects of that are minimized since it's the smooth side of the belts that are touching, it still seems like they might wear on each other over time or introduce artifacts with one belt tugging on the other slightly as it moves.
If it does cause trouble, it doesn't look like it would be too much trouble to move one belt up a few mm and the other down a few mm to get a little bit of separation between them where they cross.
Re: Compact CoreXY Build October 13, 2014 08:15PM |
Re: Compact CoreXY Build October 13, 2014 09:21PM |
Re: Compact CoreXY Build October 14, 2014 09:02AM |
Re: Compact CoreXY Build October 15, 2014 02:40PM |
Re: Compact CoreXY Build October 15, 2014 06:02PM |
Feign
It probably wouldn't be too hard to make something that separates the belts, I would just make that to ease my mind if nothing else.
Weather or not it's enough to affect printing though is up to experimentation then, the proof is in the printing. Though I agree you ought to keep an eye on the heat in the belts as well.
Re: Compact CoreXY Build October 15, 2014 09:14PM |
Re: Compact CoreXY Build October 15, 2014 09:38PM |
Re: Compact CoreXY Build October 17, 2014 04:07AM |
Re: Compact CoreXY Build November 11, 2014 09:36PM |
Re: Compact CoreXY Build November 12, 2014 10:44PM |
Re: Compact CoreXY Build November 28, 2014 07:45PM |
Re: Compact CoreXY Build November 29, 2014 04:47PM |
Re: Compact CoreXY Build December 16, 2014 09:55PM |
Re: Compact CoreXY Build December 17, 2014 12:43AM |
Re: Compact CoreXY Build December 17, 2014 06:17AM |
Re: Compact CoreXY Build December 19, 2014 11:37AM |
Re: Compact CoreXY Build December 19, 2014 04:58PM |
Re: Compact CoreXY Build December 19, 2014 05:19PM |
Re: Compact CoreXY Build December 19, 2014 05:32PM |
Re: Compact CoreXY Build January 05, 2015 07:42PM |
Re: Compact CoreXY Build February 27, 2015 08:28PM |
Re: Compact CoreXY Build February 27, 2015 09:29PM |
Re: Compact CoreXY Build February 27, 2015 09:48PM |
Re: Compact CoreXY Build February 28, 2015 10:36AM |
Re: Compact CoreXY Build March 01, 2015 05:10AM |
