What type of Hiwin! April 01, 2015 01:14PM |
Re: What type of Hiwin! April 02, 2015 02:50AM |
Re: What type of Hiwin! April 02, 2015 04:09AM |
Sorry, here's no awnser at your question but to do calculations. There's no half way because there's no reference point. And there's no price/quality ratio because how could we know the print quality you expect and the money you're ready to spend on it ? How should we estimate a component for a machine we know nothing about ? When we recommend a good component, anyway people will buy a component that fits their budget, explaining it will be "good enough".Quote
mdcompositi
Hallo,
I need to know what model of Hiwin linear rail I can use in my corexy!
I know that the perfect way is to calculate all the specific loads, speeds etc but I need a medium quality item with a good ratio price/quality!
on hiwin.com i see 3/4 options, what you suggest?
regards
So, you should awnser that question buy yourself, and the point will be the money you're ready to spend on it, because with no calculation, there's no way to know. And a system that works subjectively well on another machine means nothing on yours. There's no secret, better components will be more expensive. Do your budget allow you to buy expensive components ? Whatever, select any linear system that fits your budget, it will certainly be good enough. If you can't make up your mind between 6 types /brands, roll a dice, it works !
Re: What type of Hiwin! April 02, 2015 05:52AM |
Zavashier
mdcompositi
Hallo,
regards
I understand you don't want to calculate anything. I desagree, but it's your machine, your money and you will have from day to day to worry about this machine, not meSo, you should awnser that question buy yourself, and the point will be the money you're ready to spend on it, because with no calculation, there's no way to know. And a system that works subjectively well on another machine means nothing on yours. There's no secret, better components will be more expensive. Do your budget allow you to buy expensive components ? Whatever, select any linear system that fits your budget, it will certainly be good enough. If you can't make up your mind between 6 types /brands, roll a dice, it works !
Re: What type of Hiwin! April 02, 2015 04:12PM |
Re: What type of Hiwin! April 06, 2015 08:05AM |
I've used 3 of this [www.robotdigg.com] , two on the sides and the third on gantry.
System works good, smooth and without jerk with 400 of feedrate and 7000 for accelerations (I think also with 500 and 9000)
The only issue is some noise that I think is due to resonance of components and also due to the temporary "wood case" on wich is placed!!
Re: What type of Hiwin! April 06, 2015 08:18AM |
Re: What type of Hiwin! April 07, 2015 05:12AM |
I'm surprised. Mecanics and structures are all about calculations, or what the 5/7 years studies are for ? There's no negligible factors, even on small systems like Repraps. When I was student, somethimes we thought a component "will be good enough" but when calculations time comes, it was clear that wasn't the good component to use. Most of the times, calculations reveals things we did not thought about. Take the prusa i3 for example. How can you pretend printing proper 100µ layers with 8mm rods ? They're wrong for both X and Y axis. By the way, on the Y axis, the combination of the threaded rod chassis and the two long 8mm rods makes physicaly impossible to get a straight motion. With calculations, the right diameter to use is 12mm.Quote
LarsK
I just wanted to say that I don't think calculating the loads makes much sense on a coreXY design.
Re: What type of Hiwin! April 07, 2015 09:25AM |
Zavashier
Well, a proper set of pulleys and idlers with few extra bearings will cost you about 1% of the overall cost of the machine. As alignment is very important on any machine, and especialy on a CoreXY, maybe you don't wana save on that fiew.
LarsK
Don't do calculations if you don't need precision or speed. Then you will accept what your machine can provide, whatever the result. But if you don't do calculations, you're walking blind in a unknown environment. Your components choice may be "good enough"... or not ! There's a lot of help threads and machine that can't work through the web. The good question to awnser is "Am I ready to invest my money and my time with my eyes wide shut ?"
Re: What type of Hiwin! April 08, 2015 06:22PM |
Re: What type of Hiwin! April 09, 2015 10:51PM |
Zavashier
Well, The situation is different, but you suppose the structure is stiff enough for the linear rails. Everything matters. We're both professionnals, I'm sure we will agree whatever. For the Prusa I3, you calculate with a static load. Redo your calculations with a dynamic load, the values will change. A flex of 0.1mm is the layer height, it should just clogg up the nozzle ! Hopefully, the 8mm rods don't flex that much, but too much for me. I calculate the 8mm rods may flex about 0.05mm at the centre under 1N of dynamic load. So it could potentialy introduce a 50% error on layer height. That's big enough to me. It's a principle, but to get a 0.1mm resolution, the tolerance can't be 50%. I work for the Aircraft industry, and tolerence is 0.5% max. For a reprap 10% sounds pretty enough. And 8mm rods can't offer that tolerance. Anyway, all that don't help mdcompositi to find his guides.
Re: What type of Hiwin! April 10, 2015 12:03PM |
Re: What type of Hiwin! April 10, 2015 12:52PM |
Infact!!Quote
Zavashier
Re: What type of Hiwin! April 15, 2015 09:36AM |
Re: What type of Hiwin! April 19, 2015 09:32AM |
Re: What type of Hiwin! April 20, 2015 06:38AM |
Re: What type of Hiwin! April 21, 2015 11:55PM |
