looking to build new printer, what sliding mechanisms should i use? September 15, 2015 04:41AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 15, 2015 07:34PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 15, 2015 08:39PM |
i'm not sure i get your meaning. i have built a working delta printer but i made few mistakes with my first build, looking to fix them with a second buildQuote
cozmicray
So this is a real "Shot in the dark" build?
cozmicray
So using spectra line
--- there will be no known movement relationship between motor and extruder.
Do you intend to put on sensors / encoders to measure where things are positioned.
With timing belts --- motor moves X steps position changed by Y distance all the time!
cozmicray
Are 1 thru 8 choices?
You say use Hiwin linear slides
but
then talk about lu8uu bearings on rods
one or the other?
What are requirements -- resolution, accuracy, speed
they will show the best solution.
i am currently using a bowden, and i am having no issues with it.Quote
cozmicray
Bowden extruder --- good luck --- when all your hair is gone from frustration -- you will use a direct extruder
Re: looking to build new printer, what sliding mechanisms should i use? September 15, 2015 09:55PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 15, 2015 11:28PM |
i don't have a budget as in i am trying to find what cost can be reduced and still keep a great printer.Quote
LarsK
cozmicray is right that as long as you do not have any specifications for what you want to make or an actual budget, it is really hard to give good advice.
i plan to build the frame out of 20x20 extrusion in the hopes it will be rock solid. i have done some readings on people using linear slides and they prefer them over lm8uu's but there doesn't seem to be enough on them for me to come to a decision.Quote
LarsK
As to the essence of your question - I think few of us have tried all the options you list, I for one have not, so it is really hard to give strong input. With linear slides the quality, I believe, is proportional to the money invested. But if you do not invest in a stiff frame then you lose it all on that, and in the end Chines linear ball bearings or Hiwin slides makes no difference.
i currently have spectra on my current printer and would like to reuse most of the parts, i am not opposed to buying belts just don't want to waste my current parts. if i need to upgrade my printer to belt's later that wouldn't much of an issue as i should be able to reuse most of the parts.Quote
LarsK
What really confuses me, is the spectra lines. I do understand and like the concept. But spectra lines is a cost reduction method. The idea, along with the idea of bushings directly on extruded alu, comes from the quest to lower printer post. Not something you do to get engineering prototypes.
Re: looking to build new printer, what sliding mechanisms should i use? September 15, 2015 11:59PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 05:25AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 06:40AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 08:29AM |
bradleyk
LarsK
with my current delta the spectra is working great, i just didn't make it large enough or stiff enough.
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 10:35AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 02:04PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 10:41PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 16, 2015 11:55PM |
For this build money isn't really an issue it will just take me longer to finish the build, i just prefer to not over engineer, i like to look and idea of spectra line as well as it will keep a cleaner build.Quote
J-Max
GT2 belts and pulleys are not expensive,
easy to use and works first time, any time.
Don't ever think to save more than $10 using fishing line.
That less than $10 will save you hours
and worth its weight of wasted plastic.
++JM
That is great i will have to order some flex filament on my next order and give it a test. everywhere i have read is don't do it.Quote
J-Max
I manage to print flexible filament. There's no issue
if you print slowly and if your filament is well guided
from start to end. It's just about understanding bowden
and be patient during calibration time.
Once calibrated, it's nothing but fun.
LarsK
First, J-max as always says intelligent things and I agree with all - except the use of 2040. For your printer size (300x200x200) I am sure you can make it stiff enough with 2020.
LarsK
What I want to say, if you go for spectra lines and reuse of old parts and parts printed with a not 100% printer then stick with linear rods and bushings or run directly on the alu (don't buy the cheapest Chinese linear ball bearings no matter what)
Why are you taking apart your working printer ? How will you print new parts if you find that you need something after assembly? Why not just bite the bullet and spend those extra 100 USD to get all new parts and start from scratch?
cozmicray
Please post links to Spectra line printers
and
How they do the accuracy and precision.
How one powers the line (pulley, capstan)
--- it must be a Pull - Pull system, and it must go around a motor shaft.
How is positional accuracy maintained?
Tnx
Re: looking to build new printer, what sliding mechanisms should i use? September 17, 2015 06:27AM |
Save time and download solidworks parts @ [openbuilds.com]Quote
bradleyk
so far from this thread i have decided to use v-slot with their carriage system
i like designing in solidworks, ordering , then redesigning when i have the parts in my hand
Re: looking to build new printer, what sliding mechanisms should i use? September 17, 2015 11:22AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 18, 2015 08:56AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 18, 2015 11:10AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 18, 2015 04:05PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 18, 2015 06:40PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 05:50AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 09:55AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 12:09PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 03:47PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 05:49PM |
FatFreddie
I'm doing this with kevlar line (a bit less give than spectra) and it's working well so far. I put the motor on a length of extrusion in the middle of the uprights to minimise the angle change from winding the line around the drum.
LarsK
Two things:
First for the Z axis I think you can either stick to the more "traditional" bed design. Again, your printer is not super big. Or I think you should go all the way with the spectra wire.
Imagine if you put a stepper on that spectra wire and then you can just remove the ball screw completely. Never tried anything like it but would be really interesting. Ball screws are really what kicks the printer costs up.
thank you, that is very useful. i might be able to preload the platform with the spectra line but i have no idea how well it will work. if i stay with my current design the 20mm linear bearings are 40mm long and don't have much play but i might look at printing the z axis now and testing it before i get the printer assembled.Quote
LarsK
Whatever design you go for, you need to think about the bed wobble. The thing is you only put one bearing on each rod.
Look at the left side first. I try to sketch a design like yours moving downwards in a situation where the friction of one bearing is higher then the other. Then you risk that the bed skews like shown on the stippled lines.
Now look at the right illustration. This is what I call the "traditional" bed design. The good thing about that, is that there is a static load on each bearing. The static load is the reaction forces from the moment about the rod caused by the weight of the bed. This means that one side of the bearing will be in full contact all the time - unless bed excited by a side-verse or upwards force greater then the bed weight but that should not happen. So you have a very defined load case with good contact points. The downside of this, is that the construction needs to be pretty stiff so that it does not flex.
I am not sure how your spectra lines will play into all this. I don't have a feel for how elastic it is going to be and with all those pulleys. But I am pretty confident that you, no matter what, will need two bearings on each rod.
those 45deg bracing also server a second purpose of giving me somewhere to attach a translucent 4mm acrylic or perspex sheet to create a heated chamber.Quote
LarsK
The second thing, about your current structure with the 2020 and 2040.
For the lower rectangle I think you have it very well supported now. For connecting the vertical to the horizontal 2040 you can use plates like these:
You can also print something like that but with angles implemented. I am not so sure you need the 45 deg bracing if you do that, but it sure wont hurt and you can always remove (or implement) it later.
do you think if i used these in all those corners it will fix the issue. i would love to add 45deg bracing but they will get in the way of the linear carriage.Quote
LarsK
What I am concerned about is the upper rectangle. In particular what I am trying to sketch here:
I know in this sketch I have sketched it as a angle but in fact in your current revision you are using a steel plate - The thing is, the steel plate is even worse. Single bolts cannot take up moments of rotation. It will work like a hinge.
In general you really need to get more stiffness downwards from the upper rectangle . You need some kind of bigger plate. That plate needs to be really firmly bolted on to that 2040 horizontal and then go and connects with at least two bolts on the 2020 vertical. Or you need 45deg bracing like you did on the lower part.
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 07:37PM |
LarsK
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 08:12PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 09:37PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 10:27PM |
LarsK
I am not saying that direct spectra (1:1) wont work. It worked for Cristian - But I would probably make some good tests, as you already mentioned you want to.
Re: looking to build new printer, what sliding mechanisms should i use? September 19, 2015 10:30PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 20, 2015 12:46AM |
