CoreXY Dbot building April 07, 2016 04:18PM |
Re: CoreXY Dbot building April 11, 2016 07:36PM |
Re: CoreXY Dbot building April 12, 2016 01:09AM |
Re: CoreXY Dbot building April 12, 2016 08:30AM |
Re: CoreXY Dbot building April 12, 2016 08:34AM |
appjaws1
I am in the process of printing all the parts needed and have purchased all of the other items. I will be using an Ormerod designed extruder and plan to have 3 extruders and a diamond hotend in the future.
I will build everything first with a single extruder and then see how best to mount the extra extruders and perhaps a facility to hold 3 reels of filament.
One problem I am having is tapping qty14 5mm threads into the ends of the rails. My problem is trying to keep the tap vertical whist turning it. I am so worried that I will ruin the ends of the rails and will not be able to bolt the items together properly.
I'll update progress when I start to put it all together.
Re: CoreXY Dbot building April 12, 2016 08:43AM |
Re: CoreXY Dbot building April 12, 2016 10:12AM |
Re: CoreXY Dbot building April 12, 2016 10:42AM |
appjaws1
Re: CoreXY Dbot building April 12, 2016 01:33PM |
Re: CoreXY Dbot building April 12, 2016 02:06PM |
Re: CoreXY Dbot building April 12, 2016 02:29PM |
Edvardas
WD-40 works great for aluminum tapping and I was surprised that online machinists were recommending it as pretty much everyone else on the net says it is useless for many other things.
Re: CoreXY Dbot building April 12, 2016 03:23PM |
Re: CoreXY Dbot building April 12, 2016 03:28PM |
realthor
Length-wise they should be cut by the vendor you have purchased it from. Hacksaw will not do a clean square cut. Maybe a miter saw could do the job but I wouldn't trust that. Maybe others have actual experience cutting aluminum with the miter saw and might say otherwise.
I would be interested in DIY-able ways to cut square/flush aluminum tube/extrusion.
Re: CoreXY Dbot building April 12, 2016 03:56PM |
Re: CoreXY Dbot building April 12, 2016 05:00PM |
Re: CoreXY Dbot building April 13, 2016 11:51AM |
realthor
Re: CoreXY Dbot building April 13, 2016 04:31PM |
Re: CoreXY Dbot building April 14, 2016 06:17AM |
Re: CoreXY Dbot building April 14, 2016 10:04AM |
filipeCampos
great question... why plastic brackets in the corners? If the objective to use plastic corner it to go cheap, them is better solution to simply make holes in the middle of the aluminium extrution and use screws to make the connection.
simple and overall a great solution:
[forums.reprap.org]
Re: CoreXY Dbot building April 14, 2016 12:15PM |
realthor
I have great consideration for D-bot and its creator (and the C-bot and all the predecessors) but why plastic brackets in the corners.
Re: CoreXY Dbot building April 14, 2016 12:39PM |
Re: CoreXY Dbot building April 14, 2016 02:28PM |
vpt5566
Lots of repraps use plastic frame parts. A reprap printer is supposed to be mostly printable I believe.
vpt5566
Thanks for the tip, any good advice for cutting aluminum rails in addition to thread tapping them? Is a hacksaw clean enough
Re: CoreXY Dbot building April 14, 2016 02:53PM |
vpt5566
I still think it's a good design and I don't mind the plastic corners as long as everything bolts together tight and the rails are cut well.
Re: CoreXY Dbot building April 15, 2016 09:56AM |
Re: CoreXY Dbot building May 16, 2016 08:10AM |
Re: CoreXY Dbot building May 22, 2016 06:46PM |
ian_in_the_midlands
I am in the middle of a C-bot build now.
I cut the frames with a powered mitre saw using a cheap non-ferrous blade.
Using a couple of pieces of MDF as a long base and a fence, and a block of wood clamped down as an endstop to ensure lengths are repeatable, I found I could cut the aluminium very easily and very accurately.
I now have the cube assembled.
I have bolted it down to 18mm plywood for rigidity, mainly when carrying, and am pleasantly surprised by how rigid the frame is.
Re: CoreXY Dbot building July 01, 2016 12:05PM |
Re: CoreXY Dbot building July 01, 2016 12:40PM |
KDan
I modeled double size corner brackets for my D-Bot build and it made a definite difference in rigidity.
Regarding materials, I believe the author recommends using PETG instead of PLA or ABS.
Re: CoreXY Dbot building July 01, 2016 02:42PM |
