Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 13, 2016 10:35AM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/elongate when tensioned? June 13, 2016 05:01PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 13, 2016 06:27PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 13, 2016 09:37PM |
the_digital_dentist
Um, if the belt turns in one direction you can't use a spring tensioner because it will run into the pulleys.
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 13, 2016 09:41PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 13, 2016 11:59PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 12:34AM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 01:21AM |
the_digital_dentist
Spring loaded idlers are best applied on the low tension side of the belt loop. If the belt reverses direction, the idler alternately operates on the high and low tension sides of the loop. Since it doesn't work well on the high tension side, it's best to use only on belts that don't reverse direction, and only on the low tension side of those belt loops.
It's similar to the derailleur on a bicycle. The derailleur is always on the low tension side of the chain loop, and couldn't do its job on the high tension side.
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 01:11PM |
cozmicray
you can't use a spring tensioner if the belt turns in one direction, like the belt on auto engine.
Please advise the auto engineer designers
[attachment 79727 Auto_TB.jpg]
the_digital_dentist
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 01:47PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 03:02PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 03:29PM |
Deckingman
Er, actually as an ex automotive engineer, this is something I do know about and you both right and wrong.
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 04:17PM |
the_digital_dentist
I don't know how much 6 mm wide belt will stretch, but for the same tension, 9 mm wide belt will stretch less. It is a minor change in design to use 9 mm vs 6 mm belt, and cost difference is minimal, so I'm going to use 9 mm wide belt. When numbers aren't available, I tend to err on the side of overbuilding and it has worked well for me so far.
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? June 14, 2016 04:25PM |
cozmicray
Do you know of any work by the timing belt manufacturers for back and forth applications in CNC, 3D printing etc.
I think for 3D printer the tension device should fix initial tension of the belt, then just let it run
Tweeked every once in a while, to take out stretch and other slack
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? July 07, 2016 12:00PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? July 07, 2016 05:50PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? July 07, 2016 05:56PM |
Re: Is there any "rule of thumb" to know how much would a 6mm GT2 belt creep/stretch when tensioned? July 07, 2016 07:02PM |
