Want to build new Corexy and so many concerns February 12, 2017 12:41AM |
Re: Want to build new Corexy and so many concerns February 12, 2017 02:55AM |
Re: Want to build new Corexy and so many concerns February 12, 2017 09:00AM |
Re: Want to build new Corexy and so many concerns February 12, 2017 09:32AM |
Re: Want to build new Corexy and so many concerns February 12, 2017 10:48AM |
Re: Want to build new Corexy and so many concerns February 12, 2017 05:06PM |
Re: Want to build new Corexy and so many concerns February 12, 2017 07:55PM |
Re: Want to build new Corexy and so many concerns February 13, 2017 01:27AM |
Re: Want to build new Corexy and so many concerns February 13, 2017 11:51AM |
prot0typ1cal
I like the recent "D-Bot CoreXY in threes" by printingSome.
[www.thingiverse.com]
DD won't like the 3 stepper Z, and I don't care for the unsupported Z screws.
The 3x D-bot build does link source files. Everyone seems to have their own take on the CoreXY.
Re: Want to build new Corexy and so many concerns February 13, 2017 11:57AM |
Re: Want to build new Corexy and so many concerns February 13, 2017 01:31PM |
Re: Want to build new Corexy and so many concerns February 13, 2017 02:14PM |
Re: Want to build new Corexy and so many concerns February 13, 2017 02:44PM |
Re: Want to build new Corexy and so many concerns February 13, 2017 03:15PM |
I built my machine with a hacksaw and a drill and a drop saw. I print out the parts and glue the paper to the aluminium with glue stick then drill (a bit oversize) then cut out with the hack saw. 3mm is fine. You need a couple of files too though. I didn't find this too time consuming, motivation and confidence is the problem most people have.Quote
n9jcv
kd6hq
Thanks for the comments. I really dont see a big deal with 2 z steppers. I have an I3, running for 2 years and it has never gotten out of level. The steppers always seem to be in sync. Once leveled it is done for me. I don't use autobed leveling, just did it once very well and used bolts and nuts to secure and from there it holds. Mind you it would get out of sync if some just decided to twist a z rod. But in my world that just does not happen, no curious little children around lol. Even if it did though it would not be the end of the world, 5 min and it could be leveled again.
DD
yes, I have a hacksaw and drill and could cut corner plates, but with a hacksaw and drill that is a very time consuming process. Would probably have to use 2 or 3mm aluminum plate cutting with a hacksaw would take some time, then have to mark the holes precisely and even more precisely try and drill them. Thus I think why most just go to printed corners. Just click the print button lol
I do however have a miter saw I know I can cut 2020 extrusion with it, and that seems to work pretty well Anybody have experience cutting aluminum plate with a miter saw?
Thanks
