Re: My CoreXYU Printer project October 22, 2017 12:09PM |
Re: My CoreXYU Printer project October 22, 2017 02:33PM |
dc42
2. Lifting force. Delta printers only need to lift an effector, which is normally light in weight. You will need to lift the mass of the bed. The required torque needed per motor is:
required_torque = (bed_mass * g)/(pulley_radius * number_of_motors)
The radius of a 16 tooth GT2 pulley is (2 * 16)/(2 * pi) which is close to 5mm.
To ensure good microstepping positioning, the required torque should be no more than about 5% of the motor's holding torque (perhaps 10% at a push) - and that is after you have derated the published holding torque by 0.8 to allow for the fact that the motors will get too hot if you run them above about 80% of rated current, and by a further 0.71 to allow for using microstepping.
dc42
PS - someone recently posted here [forums.reprap.org] about compensating for leadscrew wobble by pre-processing the GCode using a Python script. I've considered supporting this type of compensation in RepRapFirmware. RRF already does XYZ skew compensation, so compensation for leadscrew wobble would be trivial to do if the wobble is constant in amplitude with increasing Z. But I suspect that will often not be the case.
Re: My CoreXYU Printer project October 22, 2017 04:37PM |
Re: My CoreXYU Printer project October 23, 2017 04:10AM |
Re: My CoreXYU Printer project October 23, 2017 06:14AM |
the_digital_dentist
I can't imagine how you'd account for all the variables in trying to compensate wobble caused by lead screws. Besides the variability of the bend in the screws, there's the axial alignment with the motor, and the variable flexibility of the screws, guide rails, and printer's frame, all of which vary as a function of Z. The problem becomes much harder when you factor in multiple screws and multiple guide rails.
Re: My CoreXYU Printer project October 24, 2017 11:06AM |
Re: My CoreXYU Printer project October 26, 2017 01:22PM |
Re: My CoreXYU Printer project October 26, 2017 09:12PM |
Re: My CoreXYU Printer project October 27, 2017 12:21AM |
prot0typ1cal
Looks like what you need is end supports (bearing mounts).
[attachment 99211 Hlid-side.jpg]
Re: My CoreXYU Printer project October 27, 2017 02:33AM |
Re: My CoreXYU Printer project October 27, 2017 08:02AM |
Re: My CoreXYU Printer project October 27, 2017 12:32PM |
lars.arvidson
I have decided to try a mount with a bearing above the coupler to stabilize the leadscrew a bit. Having the stepper on top and the leadscrew “hang” down would have been better than have the stepper in its current configuration (fixed at the bottom and floating at the top) but as I want to keep it out of the enclosure that is not possible. The long leadscrew might bend a bit under the weight (or be slightly bent from the beginning) so I might try a thicker leadscrew.
Re: My CoreXYU Printer project February 03, 2018 06:16AM |
Re: My CoreXYU Printer project February 03, 2018 06:46AM |
Re: My CoreXYU Printer project February 04, 2018 01:32AM |
Re: My CoreXYU Printer project February 04, 2018 04:10AM |
Re: My CoreXYU Printer project February 04, 2018 05:09AM |
prot0typ1cal
Love the 3 screw set up, perfect for auto bed leveling.
MKSA
What kind of bushings are you using on the vertical rods ?
Re: My CoreXYU Printer project February 05, 2018 01:10AM |
Re: My CoreXYU Printer project February 05, 2018 02:28AM |
lars.arvidson
prot0typ1cal
Yep, when you done a bit of work on the printer/bed its really easy to get it level again with the duets auto bed levelling feature.
MKSA
Printed with Igus I180. These were the first I printed. They are printed in spiral mode. I changed the design slightly for X/Y to get a thicker less wavy bushing.
Re: My CoreXYU Printer project March 04, 2018 06:45AM |
Re: My CoreXYU Printer project March 04, 2018 07:20PM |
