Re: Zasquatch's CoreXY Design/Build August 30, 2017 05:30AM |
Re: Zasquatch's CoreXY Design/Build August 30, 2017 06:47AM |
Re: Zasquatch's CoreXY Design/Build August 30, 2017 08:04AM |
Re: Zasquatch's CoreXY Design/Build August 30, 2017 09:52AM |
Re: Zasquatch's CoreXY Design/Build August 31, 2017 07:36PM |
Re: Zasquatch's CoreXY Design/Build August 31, 2017 09:26PM |
Re: Zasquatch's CoreXY Design/Build September 02, 2017 05:43PM |
Re: Zasquatch's CoreXY Design/Build September 03, 2017 06:50PM |
Re: Zasquatch's CoreXY Design/Build September 04, 2017 01:40PM |
Re: Zasquatch's CoreXY Design/Build September 04, 2017 02:06PM |
Re: Zasquatch's CoreXY Design/Build September 05, 2017 07:02PM |
Re: Zasquatch's CoreXY Design/Build September 07, 2017 10:18AM |
Re: Zasquatch's CoreXY Design/Build September 07, 2017 10:24AM |
Re: Zasquatch's CoreXY Design/Build September 07, 2017 10:25AM |
Re: Zasquatch's CoreXY Design/Build September 07, 2017 10:28AM |
nkewong
A question about how you mounted your x axis linear rail to the aluminium tubing. Did you drill an extra hole? Also, any issues on the x axis linear rail flexing?
Re: Zasquatch's CoreXY Design/Build November 12, 2017 11:02AM |
Re: Zasquatch's CoreXY Design/Build November 12, 2017 12:47PM |
Re: Zasquatch's CoreXY Design/Build November 12, 2017 02:31PM |
Re: Zasquatch's CoreXY Design/Build November 12, 2017 02:36PM |
Re: Zasquatch's CoreXY Design/Build November 15, 2017 02:49AM |
Re: Zasquatch's CoreXY Design/Build November 15, 2017 07:25AM |
Re: Zasquatch's CoreXY Design/Build November 15, 2017 12:17PM |
Re: Zasquatch's CoreXY Design/Build November 15, 2017 12:55PM |
MechaBits
Because your profile is so beefy, you probably could have got away with just one spar sticking out in the middle, maybe with the smaller one you have at the front at the back, forming the T shape.
Re: Zasquatch's CoreXY Design/Build November 15, 2017 12:58PM |
It is a bottom-mount hiwin rail. The top is solid and smooth and the back has tapped holes. I use 3d printed drill guides throughout to ensure accurate holes and it’s worked out great. Low speed, nice sharp bit, with lots of cutting oil on my drill press, no problem drilling the rail at all..... except for a considerable amount of stress leading up to it lolQuote
the_digital_dentist
I just noticed in the earlier picture, the X axis guide rail has no mounting holes! What sort of rail is that? How did you drill it?
Re: Zasquatch's CoreXY Design/Build November 15, 2017 01:47PM |
Re: Zasquatch's CoreXY Design/Build November 15, 2017 02:59PM |
MechaBits
I wouldnt have been too bothered by 2 screws at the back(one could be reference) & one at front) though I suppose once the head is in there it could be restricted, but your machine, your solution, you know why your at where your at, that's all that matters.
Re: Zasquatch's CoreXY Design/Build November 16, 2017 10:40AM |
Re: Zasquatch's CoreXY Design/Build November 16, 2017 12:43PM |
Re: Zasquatch's CoreXY Design/Build November 16, 2017 01:01PM |
the_digital_dentist
How are the leveling screws anchored to the support plate? I used teflon blocks that grip the screws tightly so they can't wobble and so the bed plate can't move laterally.
Is the bed heated?
