Problems generating/interpreting G code correctly. September 16, 2017 04:39PM |
Re: Problems generating/interpreting G code correctly. September 16, 2017 06:14PM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Problems generating/interpreting G code correctly. September 16, 2017 07:28PM |
Re: Problems generating/interpreting G code correctly. September 17, 2017 03:11AM |
the_digital_dentist
Speed? Acceleration? Jerk/junction deviation?
VDX
... most likely the printer is loosing steps ...
Re: Problems generating/interpreting G code correctly. September 17, 2017 09:02AM |
Re: Problems generating/interpreting G code correctly. September 17, 2017 12:10PM |
Re: Problems generating/interpreting G code correctly. September 17, 2017 12:20PM |
Re: Problems generating/interpreting G code correctly. September 17, 2017 05:06PM |
o_lampe
Maybe you're the first who actually uses the arc commands with Marlin? Or there's a bug in the inkscape plugin?
PS: Just opened the gcode file in CNC-Viewer and it looked OK. So it seem to be Marlin messing up the data ( surprise, surprise )
Re: Problems generating/interpreting G code correctly. September 17, 2017 05:18PM |
Re: Problems generating/interpreting G code correctly. September 19, 2017 06:06AM |
Re: Problems generating/interpreting G code correctly. September 19, 2017 10:05AM |
Re: Problems generating/interpreting G code correctly. September 19, 2017 12:38PM |
o_lampe
Yesterday I tested my CNC-mill for the first time and took your gcode file.
With DuetWiFi and RRF it looks like the math is correct in RRF. ( but the mechanical accuracy needs some tweaking )
[attachment 98210 B_gravur.jpg]
I suppose that this also applies to slicers. It's nice to know that I still have the possibility of using Marlin.Quote
691175002
Modern CAM generally segments all curves into lines and does not produce any arcs at all. Computer generated tool-paths are often too complex to be represented with G2/G3, and if your program is going to be twenty thousand lines of G1 anyways there is no point trying to slip in one or two arcs to save space.
Re: Problems generating/interpreting G code correctly. September 20, 2017 02:09AM |
Re: Problems generating/interpreting G code correctly. September 20, 2017 08:27AM |
Re: Problems generating/interpreting G code correctly. September 20, 2017 04:09PM |
Re: Problems generating/interpreting G code correctly. September 20, 2017 04:11PM |
Re: Problems generating/interpreting G code correctly. September 21, 2017 01:32AM |
