Help with cable chain for coreXY D-Bot
Posted by appjaws1
September 22, 2017 04:21AM
I am converting my D-Bot and need to have a cable chains from the base to the print gantry and from the print head to the side upright so that it fits along side the 40mm extrusion.
I have tried various designs before and found them to be loose and/or sticking when used in the side on mode.
I notice that quite a few coreXY users have cable chains and was wondering if you could share your designs and experience.
Thank you
Paul
Edited 1 time(s). Last edit at 09/22/2017 04:58AM by appjaws1.
appjaws - Ormerod 1, core XYUV Duet wifi, duex5
firmware 1.21 Web Server 1.21 Web Interface 1.21
OpenSCAD version 2016.02.09 (git 9950e6a)
slic3r-1.38.5-prusa3d and/or Simplify3D 4.0.0
Re: Help with cable chain for coreXY D-Bot
September 22, 2017 10:23AM
I've found that there is an enormous difference in quality between name-brand and chinese cable chain, so if your experiences are with ebay/aliexpress stuff maybe give Igus a try.
Plotters sometimes use a two bar linkage for cable management as well. You might be able to print something with a bearing for very low friction.
[www.itinstock.com]
October 02, 2017 04:50PM
Hi Paul,
I got mine from Ooznest [ooznest.co.uk]. I'm using 15 x 30 on it's side for the extruders/hot end and with 5 extruder motors and all the other gubbins, it's chock a block full of wires. After a couple of hundred hours or so, it's starting to sag a bit but not at all badly. I'd guess you'd have a few less wires than I have so you should be in a better position. I use a small size vertically for the bed and that's been fine. On the larger size, there are clips that open which makes getting cables through a lot easier. HTH
Ian
[somei3deas.wordpress.com]
