24V 8-bit controller board recommendations November 04, 2017 09:16AM |
Re: 24V 8-bit controller board recommendations November 04, 2017 09:44AM |
Re: 24V 8-bit controller board recommendations November 04, 2017 01:27PM |
Re: 24V 8-bit controller board recommendations November 04, 2017 01:45PM |
IQuote
o_lampe
The Rumba board is 8bit and 24V capable.
It is also Marlin compatible, but I had bad results with 0.9° steppers and RAPS128 drivers in 1/64 microsteps on a CoreXY. Now it controls my Prusa i3 with minor problems. ( LCD and USB simultaneously on locks the printer)
Re: 24V 8-bit controller board recommendations November 05, 2017 02:29AM |
Re: 24V 8-bit controller board recommendations November 05, 2017 04:34PM |
Re: 24V 8-bit controller board recommendations November 07, 2017 02:06AM |
What software drives the graphical display, smoothie type, (not marlin?)Quote
jinx
"24v compact single board design for around £25."
think if i was spending £25 or there about it be
mks genL with this TFT thou it still needs another £20 for drivers , with a little extra for the bed
Re: 24V 8-bit controller board recommendations November 07, 2017 03:09AM |
neither there a 32 bit MCU on those controllers from mks and they run there own custom software communicating over serial. in the config file you have the option to define smoothie, marlin and another cant remember! which.. the TFT24 has the single ribbon cable option where as the 28 and 32 have both the single and the traditional dual headers of the reprap smart controllersQuote
Mechabits
Re: 24V 8-bit controller board recommendations November 08, 2017 12:01AM |
Re: 24V 8-bit controller board recommendations November 08, 2017 03:08AM |
, only had a short tinker with smoothieware but I dont recall a difference in appearance, think any changes are under the hood with the way it sends commands,,, thing with mks controllers there not intended to tinker with printers like the reprap controllers where we can tweak axis and just about all things with Mks its the plug and play approach with access to features like flow,fila exchange, speeds,bed levelling "never used", continue prints after power cut and whats not.Quote
mechabits
if you run it with marlin or smoothie option the graphic display changes,
Re: 24V 8-bit controller board recommendations November 09, 2017 07:32PM |
