Making sure belts are parallel December 15, 2018 04:46PM |
Re: Making sure belts are parallel December 15, 2018 08:55PM |
Re: Making sure belts are parallel December 16, 2018 05:01AM |
Re: Making sure belts are parallel December 16, 2018 06:38AM |
The reinforcing
cord centerline will coincide with the pulley pitch diameter while the belt is in contact with the pulley. At
the same time, the outside diameter of the pulley will be in contact with the bottom of the belt tooth.
Re: Making sure belts are parallel December 16, 2018 06:53AM |
Re: Making sure belts are parallel December 16, 2018 01:03PM |
Re: Making sure belts are parallel December 16, 2018 01:49PM |
Re: Making sure belts are parallel December 16, 2018 01:55PM |
Re: Making sure belts are parallel December 16, 2018 02:39PM |
piper3d
@MadsRC very simple way of finding the distance between the idler and motor pulley: wrap a gt2 belt around your motor pulley and measure outer diameter with the belt for me it is 13.5mm, measure the diameter of the toothless idler for me it is 11.9mm. (13.5+11.9)/2=12.7mm
Re: Making sure belts are parallel December 16, 2018 03:17PM |
Re: Making sure belts are parallel December 16, 2018 03:33PM |
