From what I hear, the PTFE tubing in a bowden extruder is bit springy and it creates more of an ooze control problem. I was wondering if anyone has tried one with a braided steel cover like these:
www.summitracing.com]
These cables are designed for NOS plumbing, but they are Teflon lined. If the lining is very thin, it will probably rub through relatively quick. I don't see a spec for the Teflon thickness nor do I really know off the top of my head what thickness people use in bowden extruders. They include the fittings though, which seems more handy/stronger than trying to thread a nut on the PTFE tube. I'm thinking the steel mesh would help confine the PTFE to a specific length. I know the mesh will have a tendency to stretch a little as well, but does the combination stretch less than just a plain PTFE tube?
There has also been a lot of talk about using bowden extruders in a multiple print head setup. I'm wondering if anyone has an actual working prototype yet. I have seen that bits from bytes has a three head system, but it looks like they just use three complete print heads on a single carriage. That could be quite a lot of weight to sling around for little machines like these.
I'm trying to design a two head system for starters with the long-term goal of having six. I'm expecting problems with filament cables/heater wires and ooze primarily. I have yet to build my reprap, so I don't really know how much space I've got to work with either. Six heads might occupy too much space. I'm also thinking I need a way to adjust the print head alignment. The opening on the two nozzles I got are slightly off center, so if I don't mechanically adjust for it, then I have to somehow setup tool profiles to adjust the Gcode. Otherwise, the end of one thread will never line up with the start of the next after a tool change. I'm hoping someone has already solved at least some of these problems.
Someone mentioned using a configuration like the lenses on a microscope. Out of all the ideas I have seen, this seems like the best setup for a 4+ head system, so that is what my mental sketch-ups have centered around. The idea of rotating a barrel full of extruders sounds less complicated and less prone to failure than ejecting one tool and picking up another. Especially when you think about the wiring attached to the heater barrel. I already have plenty of ideas about hacking the firmware/hardware/software to run six heads, but that will all come after getting a two head system operational first. One step at a time.
