So I have heard back from TZ and they have said that most likely I burned the chip due to my motors not being at 6ohm or higher and the trimpot allowing too much voltage to pass through the chip. So it looks like I need to adjust my trimpot once I get the board fixed. My question is what is the best way to adjust the trimpot. Is it possible to turn the trim pot all the way down (counter clockwise?), then turn the power on with the motor connected, then signal the extruder to extrude, and turn the trimpot until the motor starts to move? (using TZ remix gen 3, extruder 2.2) Should I be measuring voltage or something as well?
