Hi Roy,
... i've programmed some format converters in past, what's pretty easy when you have ASCII sources.
Actually i have several tool-chains with the correct output for my CNC or for CAD/CAM programs for optimizing, so no need for tweaking ... but it wouldn't be a problem to switch a parser or optimizer inbetween ...
Best way will be a script reading an entire line or defined line-sequence until a delimiter or buffer-counter, then calculate the values and output linewise the correct G-code ... here you can add some routines for adjusting 'standard coordinates' to your special machine or tools too ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [
reprap.org] -- Deutsche Facebook-Gruppe - [
www.facebook.com]
Call for the project "garbage-free seas" - [
reprap.org]
