Thermistor temperature staying at "ok T:65 B:32" November 11, 2011 06:16PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 11, 2011 11:42PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 07:46PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 08:04PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 08:05PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 08:10PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 08:34PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 08:48PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 09:04PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 09:36PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 09:37PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 09:40PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 09:58PM |
#define TEMP_0_PIN 2 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#define TEMP_1_PIN 1 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
#endif
I never changed this. should i switch the numbers for now?
Re: Thermistor temperature staying at "ok T:65 B:32" November 13, 2011 10:48PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 12:20PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 04:59PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 05:00PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 05:04PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 05:30PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 05:39PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 05:42PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 14, 2011 06:29PM |
You might want to adapt a similar design to a recent post about a simple hot end. In addition to replacing the aluminum tube with a thin stainless steel tube, replace the wood block with a 1/4" aluminum plate to serve as heat sink and mounting plate. The PTFE rod above the aluminum plate can center the stainless tubing/PTFE liner into the extruder.Quote
I can do that. Should i use the Aluminum heat sinks on the stainless steal rod?
Re: Thermistor temperature staying at "ok T:65 B:32" November 15, 2011 03:21PM |
Re: Thermistor temperature staying at "ok T:65 B:32" November 15, 2011 08:44PM |
