Hi all. I'm having issues with the pulley gear attached to my y-axis motor. The timing belt is slipping off the end. I was hoping to turn the pulley around (to have the part with the grub screw on the outside of the shaft), but the shaft is not long enough to do that.
I was thinking of disassembling the threaded rod and removing the M8 bolt to the right of the motor bracket (see photo). Any suggestions?
Note also that the shaft is not exactly parallel to the threaded rod (is being pulled inwards slightly). I didn't think the belt tension was high enough as it is - let alone too high.
