Printrboard USB power SD print
Posted by jonasl
November 16, 2012 02:45AM
So I got printrboard working printing from the SD card.
I can also disconnect from pronterface, but when I pull the USB, the printer stops.
I though it was possible to completely disconnect? Any jumper for the USB power that needs to be connected?
I tried googling, but couldnt find anything.
Cheers
JOnas
Re: Printrboard USB power SD print
November 16, 2012 04:25AM
D1 diode has to be soldered in for it to work!
[reprap.org]
November 16, 2012 11:15PM
D1 is already in place, are you saying that it has not been soldered yet?
When I connect the external power supply, the blue light still comes on, so I would expect that its still powering the board.
Jonas
November 18, 2012 07:08PM
Make sure you disconnect whatever software you're using to control the bot before removing the USB connection.
