Could anyone help me in connecting a power supply to RAMPS 1.3?
I have an ATX 12v PC power supply but I'm unsure how to connect it since I'm quite new at this.
Power supply - [
i.imgur.com]
Connections - [
i.imgur.com]
EDIT: I should be clearer. I understand that the green PS-ON needs to be connected to a black ground wire. When connecting the brown sense wire to the orange +3.3V wire do I need to connect this to anything else?
When connecting the 12V to the RAMPS, is it sufficient to join the yellows together and the black wires together for each of the 2x2 connectors and wire that into the screw terminal for the 11A and 5A supply?
Can I load one of the 5V wires from the 24 pin connector and just tuck the rest of the wires away? Do I even need to load the 5V as I've heard conflicting reports on this?
Edited 1 time(s). Last edit at 04/04/2013 11:55AM by Pretengineer.
