Y axis high speed movement problems April 27, 2013 10:40PM |
Re: Y axis high speed movement problems April 28, 2013 10:17AM |
Re: Y axis high speed movement problems April 29, 2013 01:37AM |
Re: Y axis high speed movement problems April 29, 2013 05:23PM |
Re: Y axis high speed movement problems April 30, 2013 05:32AM |
You can slide the Y motor back and forth to adjust the tension, lock it in place by tightening the Y motor cap screws. Adjust the tension such that the belt is tight, but not so tight that the axis begins to bind.
Re: Y axis high speed movement problems April 30, 2013 07:15AM |
Re: Y axis high speed movement problems April 30, 2013 03:56PM |
.Quote
Run the same code again, increasing the 'F' value by perhaps 5000 each time, up to 30000. This is mm per minute, so 1000mm/m = 16mm/s, ie pretty slow! 30000mm/m = 500mm/s, ie very fast! Speed is actually limited to 500mm/s in firmware. Record at what speed it stops moving smoothly
Re: Y axis high speed movement problems April 30, 2013 07:41PM |
