Building my first printer- Prusa i3 box frame
Posted by KeptinKirk
October 06, 2013 05:43PM
Okay, this is going to be my first 3d printer build. As of right now it is planned to be a Prusa I3 box frame. Here are the parts I am going to use, I wanted someone to check and make sure I wasn't forgetting some thing. Also what would be the best kind of wood for the frame?
parts:
    5 Stepper motors NEMA 17
    2x 470mm 8mm smooth rod
    2x 370mm 8mm smooth rod
    2x 400mm M10 threaded rod
    4x 205mm M8 threaded rods
    2x 405mm 8mm smooth rod
    2x 370mm M5 threaded rod
    2 Sets Bearing Guides (4 total)
    3 Bushings
    1 X-Carriage
    1 X-End Motor
    1 X-End Pulley
    4 Y-Axis Brackets
    4 Y-Axis Corners
    1 Belt Holder
    1 Drivetrain Motor
    1 Drivetrain Pulley
    2 Lower Z-Axis
    2 Upper Z-Axis
    3 Endstop Holders
    1 Complete Gregs Wade Extruder v3 (Main Assembly, Big Gear, and Small Gear)
    Getech Reprap S-350-12 12V 29A DC single switching power supply + cables
    14 M3.5x20 screws
    46 M3.5x25 screws
    34 M8 nut
    38 M8 washer
    22 M3 nut
    19 M3 washer
    11 M3x10 bolt
    5 M3x16 bolt
    4 M3x40 bolt
    2 M8x25 bolt
    2 608zz skate bearing
    8 M5 nut
    2 plastic tubing for z coupling
    4 bulldog clips to attach glass bed
    Extruder hardware for Greg's Hinged Accessible Extruder.
    10x LM8UU bearings.
    Timing belt and aluminium pulleys (T2.5 or GT2).
    Tools: M3 alan key, M3, and M8(x2) spanners, and 2.5mm and countersink drill bits.
    1 x Complete soldered and assembled RAMPS 1.4
    1 x SD Ramps for Ramps 1.4
    1 x Iduino Mega 2560
    5 x soldered A4988 stepper driver
    5 x heatsink for A4988
    1 x Soldered and assembled panel with 4 rows LCD,SD card connector,a rotary encoder
    1 x heatbed MK2a(214mmx 214mm)
    1 x hotend2.0 wih both 0.35mm & 0.4mm nozzle
    3 m PU T5 timing belt of 7mm wide
    6 x Mechanical Endstops V1.2
    1 x USB 2.0 cable
    1 x cooler fan
    3 x 100K ohm NTC thermistor
    15 x 70cm cable set (including 5 x 2-pin,5 x 3-pin,5 x 4-pin)
Anything missing?
Re: Building my first printer- Prusa i3 box frame
October 07, 2013 06:41AM
Unless you are set on making and obtaining everything from scratch, you may want to consider this:
[www.makerfarm.com]
Seems like a really good deal.
October 07, 2013 11:25AM
I added up my total and it is about $430 for everything in the list. It seems to be cheaper to build everything from scratch.
October 07, 2013 02:16PM
It is ofc cheaper but also alot more hard and (anoying if you have problems/gotta buy other parts due they dont fit and such)
I've got the makerfarm 8inch and realy got no problems, works very good, Except i would go for the Jhead instead of Magma.
October 07, 2013 02:29PM
The list looks good. I've built built one using high quality plywood salvaged from furniture. I would avoid particle board if possible although it could be made to work if done properly.
I've only needed 4 stepper drivers for the RAMPS 1.4. Both of my Z axis motors are paired on one driver. Works well on two machines.
Personally I've found no advantage of any kind with the Makerbot style Mechanical Endstops V1.2. I much prefer simple limit switches. If you want six, are you planning on one at the beginning and end of each axis? If so, five inexpensive Micro Switch type limit switches would be good, with the sixth one being a higher quality one, like maybe a Micro Switch V3 101, I'm testing one of those right now. The better switch needs to be at the bottom of the Z axis BTW.
I should add, if you build the Y carriage out of wood, make sure to paint it. That helps keep it dimensionally stable.
Edited 1 time(s). Last edit at 10/07/2013 02:57PM by Yvan.
Yvan
Singularity Machine
October 07, 2013 04:16PM
Agree, use plywood. More plys is better and Baltic Birch is really nice but pricey. I used a 2 x 4 ' x 1/2" piece of oak plywood for the box. Was able to cut 7 strips from it and then cut them to length from there. As for dual endstops...I have never needed them on any of my CNC machines including both Prusa's. I see that T5 belts are not recommended (it's what I use on my Prusa i2) anymore, so may want to consider a different belt and pulleys.
October 07, 2013 04:35PM
I didn't notice the belt type, but it is true GT2 belts are better(and get the 20 tooth pulleys). My Prusa i1 with the T2.5 belt creates ribbing patterns on the printed parts that match the belt pitch. The GT2 has a finer pitch and is less likely to do that. I'll be testing that soon on the Prusa i3
Yvan
Singularity Machine
October 07, 2013 05:53PM
Another question what would be better a double extruder or a single?
