Kisslicer number of perimeters in thin wall sections January 16, 2014 08:51PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 08:56PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 09:01PM |
Do you know what happened I always thought it was the greatest. And was one of the reasons I decided to design and build my own machine let us knowQuote
Sublime
The Kisslicer forum is unlikely to ever be back up.
The purple lines are what Kisslicer calls "crowning" (term comes from the visualization of the data on a height map or something). It should be called adaptive extrusion width as it will extrude anywhere from 1/2 to 1-1/2 times the set extrusion width to fill in areas like that as well as for walls that can be made a single wall thickness.
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 09:03PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 09:43PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 09:57PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:16PM |
danlanigan
Wow, I wish I had of known this prior to buying a pro license yesterday. Although not contactable, it seems he is still taking money in exchange for license keys. Hopefully things will improve.
To clarify your earlier comment: are you saying that crowning should be called adaptive extrusion width or extrusion width should be called adaptive extrusion width? Originally I thought it was the later but after re-reading your post I think it is the former. If it is the former than that still doesn't explain why I am getting 4 line widths at 0.5mm each to span a 3mm wall thickness. Thanks for your help thus far.
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:19PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:21PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:23PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:28PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:30PM |
danlanigan
No complaints there, I received the key within 24 hours. Hopefully this is a sign that things are on the mend.
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:32PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:33PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:40PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:43PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 10:57PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 11:14PM |
Re: Kisslicer number of perimeters in thin wall sections January 16, 2014 11:54PM |
Re: Kisslicer number of perimeters in thin wall sections January 17, 2014 04:38AM |
