prusa i3 3dprinterczar wrong heatbed temperature from thermistor May 09, 2014 07:34AM |
Re: prusa i3 3dprinterczar wrong heatbed temperature from thermistor May 09, 2014 08:10AM |
Re: prusa i3 3dprinterczar wrong heatbed temperature from thermistor May 09, 2014 11:38AM |
Re: prusa i3 3dprinterczar wrong heatbed temperature from thermistor May 09, 2014 02:53PM |
Re: prusa i3 3dprinterczar wrong heatbed temperature from thermistor May 12, 2014 07:03AM |
cnc dick
Do you have the the thermistor plugged in the T-1 which is the second place on the ramps 1.4. Secondly in the configuration H file do you have the right motherboard picked should be 33 make sure you don't have it set up for dual extruders. If the hot end thermistor is working correctly you can test this by temporarily plugging heat bed thermistor to the hot end spot see if it works should read ambient Temp don't run the heat this way
Re: prusa i3 3dprinterczar wrong heatbed temperature from thermistor May 12, 2014 07:49AM |
