Endstop issues September 04, 2014 11:11AM |
Re: Endstop issues September 04, 2014 11:37AM |
Re: Endstop issues September 04, 2014 03:02PM |
SteveRoy
In your configure.h the Y and Z are defined to use the MIN pins on the RAMPS and the X is defined to use the MAX pins, make sure they are plugged into the correct pins on the RAMPS
Re: Endstop issues September 05, 2014 02:40AM |
Admin Registered: 13 years ago Posts: 7,025 |
Re: Endstop issues September 05, 2014 04:25AM |
Dust
You have to set your reprap mother board to the correct type. #define MOTHERBOARD 33 for a normal ramps
Dust
You have said
#define X_HOME_DIR 1,
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
Dust
Switch type endstops
#define ENDSTOPPULLUPS needs to be set.
The switches should be wired from C and NC on the switch to S and - on the ramps.
Make sure if its a min endstop its on the min ramps pins and if its a max endstop it on the max ramps pins
Also Check your ramps is fully seated on the mega
Dust
If m119 shows its changing, but it triggered when its not and vice versa then change ENDSTOPS_INVERTING from true to false or false to true, ie opposite of what is it set to now.
Dust
If your still having issues, you may have a faulty ramps or mega.
Dust
You can move the endstop to other pins reasonably easily, so if t just 1 dead pin, it can be bypassed. (by editing pins.h) more info later if you need it.
