Custom Reprap Sizing and Axis Questions
Posted by DatRoboticsGuy
December 12, 2014 05:28PM
Hello RepRap Community!
I'm new to Reprap and am going to be building a custom Reprap, but I had some questions on sizing and the use of axi. To my knowledge RepRaps aren't limited to any particular build plate sizes, obviously if I want a heated bed, which I do, I am limited to rather standard sizes for a heated bed, but for different sized build plates apart from say the prusa, where would I tell the 3d printer that the build plate size is different? The arduino code? Slic3r? Also, does RepRap have to have the y axis moving back and forth as the build plate vs the carriage and extruder moving in the x and y, axi with a makerbot style z-axis? Are there any advantages or disadvantages with moving a build plate as the y-axis? Thanks a lot!
Re: Custom Reprap Sizing and Axis Questions
December 12, 2014 06:24PM
In your firmware you can set the max lengths like this in Repetier:
#define X_MAX_LENGTH 200
#define Y_MAX_LENGTH 200
In Slic3r you can also use a custom round or rectangular shape, or set a custom bed shape like I did by importing a STL. See attached.
My printer: Raptosaur - Large Format Delta - [www.paulwanamaker.wordpress.com]
Can you answer questions about Calibration, Printing issues, Mechanics? Write it up and improve the Wiki!
open | download - Slic3r_Custom_Bed_Shape.JPG (48.2 KB)
December 12, 2014 09:05PM
Alright, Thanks Paul!
