Advice on my watercooling setup December 15, 2014 09:49PM |
Re: Advice on my watercooling setup December 16, 2014 03:12AM |
Re: Advice on my watercooling setup December 16, 2014 04:44PM |
I will be watercooling an E3DV6 hotend, 3 NEMA17s, the smoothieboard stepper drivers, and at least 2 Extruders inside of the chamber (Floating Extruder setup).
Re: Advice on my watercooling setup December 16, 2014 06:17PM |
Paul Wanamaker
3DRapidClone,
I'd like to see you succeed, I have a few worries tho...
Thanks. and I hope to answer them all.
I think that a 90C chamber temp will be too high. You will run into problems as with PLA where the filament does not freeze by the time the next layer goes over it.
Stratasys recommends between 70C-90C. Realistically, I am going to be running the chamber at 70C. But 90C is the upper limit of what it can do and I wanted to account for that.
- Unless you buy separate high amperage drivers you will not be able to achieve even 2A reliably. Perhaps if you directly water cooled the driver chips you might approach that.
The Smoothieboard Drivers are rated for max current of 2A and with either good heatsinks or watercooling I should be able to have it work fine. My Steppers are also rated for 2A
There are at least 8 issues that all combine together to affect quality at high speed:
1) Achievable stepper speed depends on voltage
2) Holding torque depends on current,
3) Acceleration - too much and it will miss steps.
4) Resonance can build up and caused missed steps, especially when doing infill (Slic3r can set different accelerations depending on the type being printed)
5) Moving mass of the effector, bearing blocks etc VS (a combination of acceleration + holding torque + resonance), a larger mass must have lower acceleration. Make it as light as possible.
6) The extrusion must cool enough between layers
7) Printing fast means higher hot end pressures, and the hot end has to be pressurized and depressurized rapidly or you will get blobbing. This is more difficult with a long bowden tube, and requires special firmware settings.
8) The hot end has to be able to extrude quickly enough.
I really do not understand why you want to put _any_ silicon electronics in the heated chamber. That's asking for big trouble. Since it's a Delta, your steppers could also be outside.
My steppers for moving the machine are in fact outside of the chamber, I just wasn't sure that using high current with high acceleration at high speed would make the stepper motors far too hot. I have found out that, that only current really makes the stepper motor hot and not how fast it accelerates. So it was just a safeguard to prevent overtemp protection. They won't be cooled by watercooling anymore, just heatsinks.
As for the the moving mass of the effector, it should still be extremely light. An RC water jacket is designed for RC boats so weight is of great concern. The water jacket only weighs in at about 14g. The tubing I will use is pretty small in diameter so the flow rate makes up for that. This also means the amount of water flowing through and onto the hotend will be lighter.
For the rapid pressure and depressurizing, It is the reason I am using a floating extruder setup and explains why I am having the extruder inside the chamber which then also explains why I am using watercooling. This means I can reduce the the bowden tube length down to about 100mm greatly increasing my ability to print flexible materials and decreasing blobbing and stringing which is important with high speed.
If the E3DV6 proves to be insufficient, I will be using the Prometheus hotend which allows me to customize the melting zone for higher speed printing.
I am still working on improving the extruder design however. I'll publish everything I get from my experimentation though on my blog once its up and running
For the radiator block, you can use an auto heater core as your radiator. I had a water cooled PC I built that used one years ago with two slow and nearly silent 120mm fans on it, with a bit of antifreeze to keep things happy inside. You could smell that a bit tho... Used a large aquarium pump.
I will be using either no radiator or a single 120mm (no fan) radiator to cool the system. Other than the extruder inside, there isn't much heat to be dissipated. 2 extruders, hotend essentially.
Good luck with your build
Thank you.
Re: Advice on my watercooling setup December 16, 2014 07:59PM |
