Hey guys, using slicr3 and repetier my hotend temp readout varies from about 250c to 220c during print at a setting of 230c. Average is about 225c. Is this normal. I read about trying different heat settings adjusting in one degree increments. There is no way. Cheap Chinese thermistor? Are you seeing this on your machines? For what it's worth, printing ABS is working perfectly. I mounted an extra fan were filament enters to eliminate melting above extruder. Made all the difference. Thanks.
