What firmware are you using? Marlin has a setting in the config.h where you can set the LCD type, which is disabled by default.
Edit: ah, I see that you had it working, the it stopped. in which case, double check connectors. If there was any kind of ESD, it may have damaged the LCD, LCD controller or the RAMPS board or arduino.
Edited 1 time(s). Last edit at 01/26/2015 05:13PM by SupraGuy.
