Can you drill borosilicate glass
Posted by mikes3ds
April 15, 2015 03:04PM
Simple question
Can you drill holes borosilicate glass? Do you need special drill-bit or what drill-bit should use?
(I dont want to crack)
Re: Can you drill borosilicate glass
April 15, 2015 05:19PM
Ive used glass bits before.
They are shaped like a spade and normally have a diamond coating.
April 16, 2015 06:41AM
I think you're supposed to build a circular wall around the hole using plasticine (or similar) to contain some coolant - white spirit rings a bell. I think that's for ordinary float glass though - I don't know if borosilicate glass is stress-free. I'd be very nervous if I had to do it.
Edited 1 time(s). Last edit at 04/16/2015 06:41AM by David J.
