So i'm printing out a rotating V12 engine for fun. Now that i need more accurate parts i now need to actually figure out how to make the first layers the same width as the rest.
What i mean is , i print a 10mm long 3mm wide conencting rod for the piston. The bottom of this rod is .3mm larger in diameter than the rest of the rod.
What do i need to do to fix this?
All searches i do keep coming up with extrusion width for ADHESION purposes, i'm not having any problems with adhesion.
