I'm a Newbie here, and I'm sure there's a simple answer to this,,,
Why do the 6-12v motors have a 3.9MM shaft, but all of the gears are 5MM? When I tighten the screws of the gear (onto the flat portion of the motor shaft) The gear spins off-center. How do I get the 5MM bore gears and pulleys centered on the smaller 3.9MM motor shaft? Do I need a bushing?
Perplexed on this! Thanks for any advice!
