Heatbed will not heat to 110 May 30, 2015 06:40AM |
Re: Heatbed will not heat to 110 May 30, 2015 11:30AM |
Re: Heatbed will not heat to 110 May 30, 2015 11:31AM |
Re: Heatbed will not heat to 110 May 30, 2015 11:52AM |
Floyd
Might be the power supply.
Most people run 12v 30amp PSU's
Re: Heatbed will not heat to 110 May 31, 2015 07:03AM |
Re: Heatbed will not heat to 110 May 31, 2015 11:51AM |
Re: Heatbed will not heat to 110 June 01, 2015 08:27AM |
The science behind this is the one, I had on the printer is one I made up. The one I just put on the printer, Is a premade one, made for the printer. So how am I cheating myself? So anyhow I now setup the themistor center under the bed, which I can get the bed to 110 deg, if I want to wait for it. I set the bed temperature to 100 deg, which works fine when printing, so it will shout down sooner. I have order insulation for the bed, when I get it I will reset the temperature.Quote
o_lampe
tobig11
Change the wire to the thermistor to a thinner wire. This got me to 90 degrees.
Wow, what is the science behind this?
It sounds, like you are only cheating yourselve.
Sorry, don´t take it pesonal
-Olaf
