Custom FDM Needs Print Bed June 06, 2015 07:52PM |
Re: Custom FDM Needs Print Bed June 06, 2015 10:19PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Custom FDM Needs Print Bed June 08, 2015 07:02PM |
Re: Custom FDM Needs Print Bed June 08, 2015 08:30PM |
Re: Custom FDM Needs Print Bed June 08, 2015 08:47PM |
Re: Custom FDM Needs Print Bed June 09, 2015 12:30AM |
Re: Custom FDM Needs Print Bed June 09, 2015 12:51AM |
Re: Custom FDM Needs Print Bed June 09, 2015 08:04AM |
Re: Custom FDM Needs Print Bed June 09, 2015 10:27AM |
Re: Custom FDM Needs Print Bed June 09, 2015 12:11PM |
sungod3k
40 watt should be enough if you slow down. it depends what you extruder can handle, but the heater is definitely a weak point. would be interesting to see how 60watt cartridges behaves
Re: Custom FDM Needs Print Bed June 09, 2015 08:24PM |
Re: Custom FDM Needs Print Bed June 10, 2015 03:30AM |
epicepee
I wouldn't use normal float glass, I don't think it's usually flat enough. If you look in the window, your reflection bends a little as you move, right?
Re: Custom FDM Needs Print Bed June 10, 2015 03:36AM |
Tinkerhabits
I have decided to use true tempered glass for the thermal transference
Perhaps 2 of these [www.zoro.com]
or $900 on [www.oemheaters.com]
