Hi all
I have searched and cant find my answer.
I just picked up my first ever printer (Ormerod 2) and began assembly. I got as far as updating the firmware, and SD card and it went smoothly. Everything updated, printer online etc etc.
The issue i have is when i remove the usb, then plug in the 12v supply at the ''Now connect the power supply unit'' stage of commissioning.
There IS Kapton tape insulating the duet.
There IS a jumper at JP10 (ATX_5V_EN)
The hot end fan does not turn on at all
The board gives out a loud continuous beeping noise.
I bought the kit from Radionics (RS) and have read that some of duet boards with these kits are faulty?
Any thoughts or comments? I am currently taking the board out to double check it isn't shorting and will report back.
Rhys
