Kossel 2020 with Marlin firmware loaded - LCD screen and controls don't work
Posted by djtrance2
September 25, 2015 01:48AM
Hi all,
Thanks to your help, I've finally been able to print a calibration pattern.
I have to print from my computer using Repetier. This is because since I loaded the Marlin firmware, the LCD screen shows a blank screen.
What do I need to do to make the screen work again? This also means the button to control and load the SD card files also does not do anything. I did a file compare and the configuration files look very similar.
Re: Kossel 2020 with Marlin firmware loaded - LCD screen and controls don't work
September 25, 2015 03:13AM
It would be helpful to attach your configuration.h
-Olaf
September 26, 2015 01:09AM
Here is the configuration.h
open | download - Configuration.h (26 KB)
September 26, 2015 02:56AM
I've uploaded all my code on github in case you want to see all the files
[github.com]
September 26, 2015 03:43AM
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
You havenĀ“t defined any LCD controller.
-Olaf
September 26, 2015 11:07AM
Thank you! that was it. I got confused by the "discount" tag.
