Just printed a mount and added a 40mm print cooling fan to my prusa steel to help with overhangs but it only seems to turn on briefly even though I can see on the LCD that it should be going.
I've tried sending m106 through printrun and it only turns on for a moment.
The voltage coming out of D9 is 12.05 and the fan is rated 12V, 0.07A. I'm wondering if the trim pot on the pololu drv8825 is set wrong but going by the stepper logic I've set the voltage as .035 and while it goes for slightly longer it's certainly not continuous...
I must be missing something obvious
