Help installing marlin properly April 12, 2016 02:43AM |
Re: Help installing marlin properly April 12, 2016 06:14AM |
Admin Registered: 13 years ago Posts: 7,008 |
Re: Help installing marlin properly April 12, 2016 06:32AM |
Re: Help installing marlin properly April 12, 2016 05:33PM |
Re: Help installing marlin properly April 12, 2016 06:07PM |
Re: Help installing marlin properly April 12, 2016 06:15PM |
Re: Help installing marlin properly April 12, 2016 06:28PM |
Re: Help installing marlin properly April 12, 2016 07:39PM |
Re: Help installing marlin properly April 12, 2016 10:09PM |
Re: Help installing marlin properly April 12, 2016 10:19PM |
Re: Help installing marlin properly April 12, 2016 11:09PM |
Re: Help installing marlin properly April 13, 2016 06:02AM |
Re: Help installing marlin properly April 14, 2016 02:35PM |
Re: Help installing marlin properly April 14, 2016 03:01PM |
EDIT 2: ok I still have yet to test the other axes like you mentioned I started hearing some static'y noises from the board I'm using. maybe the stepper driver? anyway, I decided to touch the heatsink to see if it was warm, and found it to be extremely hot to the point where as soon as I placed my finger on it, my reaction was to pull it off immediately. should it get that hot? also the stepper motor was warm which I assume is normal. it wasn't under any kind of stress, is this heat normal? thanks
Re: Help installing marlin properly April 14, 2016 03:05PM |
Re: Help installing marlin properly April 14, 2016 03:07PM |
Re: Help installing marlin properly April 14, 2016 03:21PM |
Re: Help installing marlin properly April 14, 2016 03:29PM |
Re: Help installing marlin properly April 14, 2016 08:50PM |
Re: Help installing marlin properly April 14, 2016 09:57PM |
Re: Help installing marlin properly April 14, 2016 10:38PM |
Re: Help installing marlin properly April 15, 2016 02:47AM |
Re: Help installing marlin properly April 15, 2016 05:06AM |
Re: Help installing marlin properly April 16, 2016 05:18AM |
#define HOMING_FEEDRATE {50*60,50*60,2.5*60, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {160, 160, 5120, 250} // default steps per unit for Ultimaker #define DEFAULT_MAX_FEEDRATE {200, 200, 3, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {3000, 3000, 100, 1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 15.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Help installing marlin properly April 16, 2016 06:41AM |
Re: Help installing marlin properly April 16, 2016 06:57AM |
