You'll probably find that the bed surface isn't flat enough to print on. That is why people usually put a piece of glass on it. The other problem is one of design- there are usually 4 screws to level the bed at its corners. 3 points define a plane. 4 points define a potato chip. Turning any one of the leveling screws will cause the bed and undercarriage to bend, not to become level. I don't know why they keep using 4 point "leveling". It's just dumb.
Something else they probably didn't tell you- though they may have claimed compatibility with ABS filament, the bed probably won't get hot enough to get prints to stick without adding glue and since the printer isn't enclosed, if you try to print anything but small ABS parts they will delaminate.
Ultra MegaMax Dominator 3D printer: [
drmrehorst.blogspot.com]
