MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 03:41AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 04:50AM |
Admin Registered: 13 years ago Posts: 7,026 |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 05:49AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 06:08AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 06:15AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 06:21AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 06:39AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 07:01AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 07:02AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 07:37AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 08:03AM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 27, 2016 05:03PM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 28, 2016 04:22PM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? July 29, 2016 12:34PM |
Re: MKS Base v1.3 - Z axis moves when switch triggered !? August 01, 2016 03:53AM |
Connecting... Printer is now online. Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 Bad value for variable 'last_file_path', expecting type 'str' (ascii) 3.0 mm of filament used in this print the print goes from 74.925000 mm to 109.691000 mm in X and is 34.766000 mm wide the print goes from 71.613000 mm to 123.278000 mm in Y and is 51.665000 mm wide the print goes from 0.000000 mm to 64.451000 mm in Z and is 64.451000 mm high Estimated duration (pessimistic): 1 layers, 1:03:24 Print Started at: 20:04:45 DEBUG: P0:1.1547 DEBUG: P1:1.5516 SENDING:M106 DEBUG: P2:1.3312 WARNING: probe is not within tolerance: 1.154687 > 0.030000 DEBUG: plane normal= -0.002098, 0.002330, -0.999995 Probe completed, bed plane defined SENDING:M107 Paused. Disconnected. Bad value for variable 'last_file_path', expecting type 'str' (ascii) 3.0 mm of filament used in this print the print goes from 74.925000 mm to 109.691000 mm in X and is 34.766000 mm wide the print goes from 71.613000 mm to 123.278000 mm in Y and is 51.665000 mm wide the print goes from 0.000000 mm to 64.451000 mm in Z and is 64.451000 mm high Estimated duration (pessimistic): 1 layers, 1:03:24 Connecting... Printer is now online. Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 Print Started at: 20:10:37 T:209.7 /210.0 @72 T:209.7 /210.0 @72 T:209.7 /210.0 @72 T:209.9 /210.0 @71 T:209.7 /210.0 @72 T:209.9 /210.0 @71 DEBUG: P0:1.1734 DEBUG: P1:1.6312 DEBUG: P2:1.3859 WARNING: probe is not within tolerance: 1.173438 > 0.030000 DEBUG: plane normal= -0.002346, 0.002715, -0.999994 Probe completed, bed plane defined Paused. >>>m114 SENDING:M114 ok C: X:99.366 Y:93.264 Z:0.200 A:99.366 B:93.267 C:1.545 E:12.194 Reset. Smoothie Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 Bad value for variable 'last_file_path', expecting type 'str' (ascii) 3.0 mm of filament used in this print the print goes from 75.005000 mm to 109.518000 mm in X and is 34.513000 mm wide the print goes from 71.394000 mm to 123.339000 mm in Y and is 51.945000 mm wide the print goes from 0.000000 mm to 64.451000 mm in Z and is 64.451000 mm high Estimated duration (pessimistic): 1 layers, 1:17:44 Reset. Setting hotend temperature to 210.000000 degrees Celsius. Smoothie SENDING:M105 Bad value for variable 'last_file_path', expecting type 'str' (ascii) 3.0 mm of filament used in this print the print goes from 75.005000 mm to 109.518000 mm in X and is 34.513000 mm wide the print goes from 71.394000 mm to 123.339000 mm in Y and is 51.945000 mm wide the print goes from 0.000000 mm to 64.451000 mm in Z and is 64.451000 mm high Estimated duration (pessimistic): 1 layers, 1:17:44 Print Started at: 20:16:27 DEBUG: P0:0.0984 DEBUG: P1:0.0375 DEBUG: P2:0.0484 WARNING: probe is not within tolerance: 0.098437 > 0.030000 DEBUG: plane normal= 0.000129, -0.000429, -1.000000 Probe completed, bed plane defined Paused. >>>m114 SENDING:M114 ok C: X:102.375 Y:82.103 Z:10.150 A:102.373 B:82.106 C:10.234 E:6.924 Disconnected. Connecting... Printer is now online. Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 Bad value for variable 'last_file_path', expecting type 'str' (ascii) 3.0 mm of filament used in this print the print goes from 75.005000 mm to 109.518000 mm in X and is 34.513000 mm wide the print goes from 71.394000 mm to 123.339000 mm in Y and is 51.945000 mm wide the print goes from 0.000000 mm to 64.451000 mm in Z and is 64.451000 mm high Estimated duration (pessimistic): 1 layers, 1:17:44 Print Started at: 20:22:17 T:209.7 /210.0 @69 T:209.6 /210.0 @70 T:209.6 /210.0 @71 T:209.7 /210.0 @69 T:209.7 /210.0 @69 T:209.9 /210.0 @67 T:209.9 /210.0 @67 T:209.9 /210.0 @67 DEBUG: P0:1.1437 DEBUG: P1:1.5469 DEBUG: P2:1.2953 WARNING: probe is not within tolerance: 1.143750 > 0.030000 DEBUG: plane normal= -0.002366, 0.002281, -0.999995 Probe completed, bed plane defined Paused. Reset. Smoothie Print Started at: 20:23:12 DEBUG: P0:0.0875 DEBUG: P1:0.0813 DEBUG: P2:0.0875 WARNING: probe is not within tolerance: 0.087500 > 0.030000 DEBUG: flat plane Probe completed, bed plane defined SENDING:M106 Paused. Reset. Smoothie Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 Print Started at: 20:26:38 DEBUG: P0:1.0219 DEBUG: P1:1.5391 DEBUG: P2:1.3187 WARNING: probe is not within tolerance: 1.021875 > 0.030000 DEBUG: plane normal= -0.002170, 0.003244, -0.999992 Probe completed, bed plane defined Paused. Reset. Smoothie Print Started at: 20:27:10 ZProbe triggered before move, aborting command. Paused. Reset. Smoothie Setting hotend temperature to 210.000000 degrees Celsius. SENDING:M105 Print Started at: 20:28:07 DEBUG: P0:0.2047 DEBUG: P1:0.1000 DEBUG: P2:0.0734 WARNING: probe is not within tolerance: 0.204688 > 0.030000 DEBUG: plane normal= -0.000162, -0.000877, -1.000000 Probe completed, bed plane defined SENDING:M107 SENDING:M106 SENDING:M107 Paused. Paused. Print Started at: 20:31:17 SENDING:M106 Paused. Paused. Print Started at: 20:36:00 Paused. Paused. Print Started at: 20:36:08 Paused. Print Started at: 20:39:52 DEBUG: P0:0.9094 DEBUG: P1:1.4266 DEBUG: P2:1.2469 WARNING: probe is not within tolerance: 0.909375 > 0.030000 DEBUG: plane normal= -0.001826, 0.003370, -0.999993 Probe completed, bed plane defined Paused. Print Started at: 20:40:24 ZProbe triggered before move, aborting command. Paused. Print Started at: 20:40:43 DEBUG: P0:0.3828 DEBUG: P1:0.3078 DEBUG: P2:0.2688 WARNING: probe is not within tolerance: 0.382812 > 0.030000 DEBUG: plane normal= -0.000286, -0.000691, -1.000000 Probe completed, bed plane defined SENDING:M107 SENDING:M106 Paused.
