I recently bought a pursa i3 reprap kit online. Attached is a picture of the one I bought. I have assembled it but the motor on the extruder doesn't seem to be working. Initially it did print a little bit but resulted in a mess, not much came out. It also seemed like the filament was being pulled out a little bit rather than pushed in - it only extruded a bit after I applied a bit of force to push the filament. I rotated the extruder round so if it was going the wrong direction, I would now push instead of pull the filament. However, now I don't get any response at all. When I go to motion on the lcd and set mm the motor does nothing. I don't think the motor is broken as I have plunged it in a different socket and it works fine. I have also tried swapping the drivers and got the same result. Does this mean that my motherboard is faulty?
Thanks very much for your time and help.
Edited 5 time(s). Last edit at 10/02/2016 07:06AM by volmer.
open |
download -
(84.6 KB)
