I've seen the issue of the Z axis motor overheating and skipping steps around this forum and other forums as well. Some recommend turning OFF the Z axis motor in the firmware when it is not in use, as a stepper will generate a lot of heat when ON but not moving. However, doing this can cause the Z axis to slide down slightly because of the vibration of the X axis and Y axis.
What do each of you use, and what is preferable?
-Keeping the Z axis ON, causing excessive heating. I use little 5v fans attached to the Z motors to prevent this.
OR
-Turning the Z axis OFF, which stops overheating, but may cause the whole Z axis to move down due to X and Y movement.
Edited 1 time(s). Last edit at 08/13/2012 12:34PM by Lodorenos.
