Number of problems with new Reprap Prusa i3 October 19, 2017 07:27AM |
Re: Number of problems with new Reprap Prusa i3 October 19, 2017 12:39PM |
Re: Number of problems with new Reprap Prusa i3 October 19, 2017 03:37PM |
Re: Number of problems with new Reprap Prusa i3 October 19, 2017 05:06PM |
Admin Registered: 13 years ago Posts: 7,007 |
1. Could not compile & upload the RepRapGuru Marlin v3 software - it complains about a missing u8glib.h library. Thus we are using the RepRapGuru Marlin v2 software. Could using the V2 instead of V3 software be the cause of the problems?
2. Stepper driver PCBs did not fit perfectly into their slots - they were about 0.5mm too long. After sanding them down, they now fit.
thermocouples and thermistors are quite different things. That resistance is really high for a Thermistor, most are 100K at about 25c.Quote
3. Heated bed thermocouple reports the ambient temperature to be 0 Celcius. Resistance across the disconnected thermistor is ~500 kOhms.
Bed will not heat if it cant read a temperature, safety feature. I would think both should be the same...Quote
4. Hot bed does not heat. Extruder nozzle heats fine. Resistance across the disconnected extruder thermistor is ~100 kOhms. Are the extruder and hot bed thermistors the same?
Re: Number of problems with new Reprap Prusa i3 October 20, 2017 12:46AM |
Re: Number of problems with new Reprap Prusa i3 October 22, 2017 03:35AM |
Re: Number of problems with new Reprap Prusa i3 October 22, 2017 05:09AM |
Re: Number of problems with new Reprap Prusa i3 October 22, 2017 06:04AM |
Dust
Post a link to this firmware you are using as this V2 and V3 doesn't correspond to anything standard
Post a link to what your brought also... so we know what you taking about.
Basically the firmware has to know about your hardware, if you just try any random old firmware, its like putting a dolphins brain into a dog, it might fit, but it never going to work
1) identify your motherboard, ramps and Melzi are the most common.
2) examine the configuration.h file... you have to edit that to match your hardware.
I'm somewhat surprised that it didn't already come with firmware....
Re: Number of problems with new Reprap Prusa i3 October 22, 2017 06:42AM |
Re: Number of problems with new Reprap Prusa i3 October 22, 2017 08:21AM |
Re: Number of problems with new Reprap Prusa i3 October 22, 2017 11:22AM |
Re: Number of problems with new Reprap Prusa i3 October 23, 2017 04:27AM |
