Auto-Leveling crashes into bed upon printing June 17, 2016 09:35PM |
; Default start code M501 ;Read out EEPROM settings G28 ; Home extruder G29 V4; Auto Level M851 Z -4.67; M500 ;Save EEPROM settings M501 ;Read out new EEPROM settings G1 Z15 F{Z_TRAVEL_SPEED} M107 ; Turn off fan G90 ; Absolute positioning M82 ; Extruder in absolute mode {IF_BED}M190 S{BED} ; Activate all used extruder {IF_EXT0}M104 T0 S{TEMP0} G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature {IF_EXT0}M109 T0 S{TEMP0}
21:26:52.972 : echotored settings retrieved 21:26:52.977 : echoteps per unit: 21:26:52.977 : echo: M92 X80.00 Y80.00 Z400.00 E96.00 21:26:52.977 : echo:Maximum feedrates (mm/s): 21:26:52.981 : echo: M203 X250.00 Y250.00 Z2.00 E22.00 21:26:52.981 : echo:Maximum Acceleration (mm/s2): 21:26:52.985 : echo: M201 X1000 Y1000 Z5 E1000 21:26:52.985 : echo:Acceleration: S=acceleration, T=retract acceleration 21:26:52.989 : echo: M204 S500.00 T500.00 21:26:52.993 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 21:26:52.997 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 21:26:52.997 : echo:Home offset (mm): 21:26:52.997 : echo: M206 X0.00 Y0.00 Z0.00 21:26:53.001 : echoID settings: 21:26:53.001 : echo: M301 P22.20 I1.08 D114.00 21:27:26.853 : Bed x: 30.00 y: 20.00 z: 5.34 21:27:50.923 : Bed x: 140.00 y: 20.00 z: 3.41 21:28:11.887 : Bed x: 140.00 y: 110.00 z: 3.98 21:28:28.899 : Bed x: 30.00 y: 110.00 z: 5.75 21:28:28.903 : Eqn coefficients: a: -0.02 b: 0.01 d: 5.70 21:28:28.907 : planeNormal x: 0.02 y: -0.01 z: 1.00 21:28:28.907 : echo:endstops hit: X:-9.95 Z:5.76 21:28:29.362 : echoettings Stored 21:28:29.399 : echotored settings retrieved 21:28:29.399 : echoteps per unit: 21:28:29.399 : echo: M92 X80.00 Y80.00 Z400.00 E96.00 21:28:29.403 : echo:Maximum feedrates (mm/s): 21:28:29.403 : echo: M203 X250.00 Y250.00 Z2.00 E22.00 21:28:29.408 : echo:Maximum Acceleration (mm/s2): 21:28:29.408 : echo: M201 X1000 Y1000 Z5 E1000 21:28:29.408 : echo:Acceleration: S=acceleration, T=retract acceleration 21:28:29.412 : echo: M204 S500.00 T500.00 21:28:29.416 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 21:28:29.420 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 21:28:29.420 : echo:Home offset (mm): 21:28:29.424 : echo: M206 X0.00 Y0.00 Z0.00 21:28:29.424 : echoID settings: 21:28:29.424 : echo: M301 P22.20 I1.08 D114.00 21:29:10.021 : Printing layer 1 of 100
//=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // Uncomment the following line to enable CoreXY kinematics // #define COREXY // coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignord if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. #define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Disable max endstops for compatibility with endstop checking routine #if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS) #define DISABLE_MAX_ENDSTOPS #endif // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER true //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops false //If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops false //If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 182 // was 200 #define X_MIN_POS 0 #define Y_MAX_POS 110 // was 200 #define Y_MIN_POS 0 #define Z_MAX_POS 175 #define Z_MIN_POS 0 // was 0 changed to -5 to allow Z to go below initial home level on unlevel bed where another corner was lower than initial home level #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS) //============================= Bed Auto Leveling =========================== #define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) #define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled. #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 30 #define RIGHT_PROBE_BED_POSITION 140 #define BACK_PROBE_BED_POSITION 110 #define FRONT_PROBE_BED_POSITION 20 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 2 #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 50 #define ABL_PROBE_PT_1_Y 150 #define ABL_PROBE_PT_2_X 80 #define ABL_PROBE_PT_2_Y 120 #define ABL_PROBE_PT_3_X 160 #define ABL_PROBE_PT_3_Y 50 #endif // AUTO_BED_LEVELING_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) // X and Y offsets must be integers #define X_PROBE_OFFSET_FROM_EXTRUDER 40 #define Y_PROBE_OFFSET_FROM_EXTRUDER -25 #define Z_PROBE_OFFSET_FROM_EXTRUDER -4.67 //actually around -5 #define Z_RAISE_BEFORE_HOMING 0 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 5000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 1 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 1 //How much the extruder will be raised when traveling from between next probing points //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like. //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. // You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. // #define PROBE_SERVO_DEACTIVATION_DELAY 300 //If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif #ifdef AUTO_BED_LEVELING_GRID // Check if Probe_Offset * Grid Points is greater than Probing Range #if X_PROBE_OFFSET_FROM_EXTRUDER < 0 #if (-(X_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION)) #error "The X axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #else #if ((X_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (RIGHT_PROBE_BED_POSITION - LEFT_PROBE_BED_POSITION)) #error "The X axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #endif #if Y_PROBE_OFFSET_FROM_EXTRUDER < 0 #if (-(Y_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION)) #error "The Y axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #else #if ((Y_PROBE_OFFSET_FROM_EXTRUDER * AUTO_BED_LEVELING_GRID_POINTS) >= (BACK_PROBE_BED_POSITION - FRONT_PROBE_BED_POSITION)) #error "The Y axis probing range is not enough to fit all the points defined in AUTO_BED_LEVELING_GRID_POINTS" #endif #endif #endif #endif // ENABLE_AUTO_BED_LEVELING // The position of the homing switches //#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: // For deltabots this means top and center of the Cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 0 //#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing. //// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 50, 0} // set the homing speeds (mm/min) // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,400,96} // default steps per unit for ultimaker {78.7402,78.7402,200*8/3,760*1.1}920 previous value for z 3840 #define DEFAULT_MAX_FEEDRATE {250, 250, 2, 22} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {1000,1000,5,1000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for r retracts // Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing). // The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder). // For the other hotends it is their distance from the extruder 0 hotend. // #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis // #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec) //=========================================================================== //=============================Additional Features=========================== //=========================================================================== // Custom M code points #define CUSTOM_M_CODES #ifdef CUSTOM_M_CODES #define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851 #define Z_PROBE_OFFSET_RANGE_MIN -15 #define Z_PROBE_OFFSET_RANGE_MAX -1 #endif // EEPROM // The microcontroller can store settings in the EEPROM, e.g. max velocity... // M500 - stores parameters in EEPROM // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. //define this to enable EEPROM support #define EEPROM_SETTINGS //to disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out: // please keep turned on if you can. #define EEPROM_CHITCHAT
Re: Auto-Leveling crashes into bed upon printing June 20, 2016 05:25PM |
Re: Auto-Leveling crashes into bed upon printing June 20, 2016 05:42PM |
roko
I confess I am new at that also, but my question is:
Why do you need to autolevel every print?
Shouldn't autolevelling one time work and then correct your Z height to be correct for printing thereafter?
If something changed physically, I could see why you would repeat autolevel.
Not trying to be rude, just curious.
Re: Auto-Leveling crashes into bed upon printing June 25, 2016 11:11AM |
Re: Auto-Leveling crashes into bed upon printing June 25, 2016 10:23PM |
Re: Auto-Leveling crashes into bed upon printing April 23, 2018 01:26AM |
Re: Auto-Leveling crashes into bed upon printing April 23, 2018 11:42AM |
Re: Auto-Leveling crashes into bed upon printing April 24, 2018 01:57PM |
Re: Auto-Leveling crashes into bed upon printing April 26, 2018 01:16PM |
Re: Auto-Leveling crashes into bed upon printing April 27, 2018 06:50AM |
Admin Registered: 13 years ago Posts: 7,005 |
Re: Auto-Leveling crashes into bed upon printing May 10, 2018 02:39AM |
