Hotend doesnt heat up June 24, 2018 03:57PM |
Re: Hotend doesnt heat up June 24, 2018 04:31PM |
Re: Hotend doesnt heat up June 24, 2018 05:03PM |
Re: Hotend doesnt heat up June 24, 2018 05:17PM |
Re: Hotend doesnt heat up June 24, 2018 06:39PM |
hichamom
thanks for the reply Roberts i dont use the heat bed
no the hotend does heat at all it remains 0 degree
Re: Hotend doesnt heat up June 24, 2018 07:19PM |
SteveRoy
It should show room temp at least. Start with the thermistor.
Re: Hotend doesnt heat up June 25, 2018 01:53AM |
here is an image for better explainQuote
Roberts_Clif
SteveRoy
Correct
It Should show about 20-25C
Don't believe I have ever seen exactly 0C
Use a hair dryer see if you can heat the hot-end heater Block and change the temperature.
Until the hot-end temperature reaches 15C Marlin Firmware will not allow the Controller to switch the power on to the hot-end.
Re: Hotend doesnt heat up June 25, 2018 01:58AM |
Admin Registered: 13 years ago Posts: 7,005 |
exit status 1 #error "Unknown MOTHERBOARD value set in Configuration.h"
Re: Hotend doesnt heat up June 25, 2018 08:44PM |
