Steps per mm not updating with new Marlin Flash July 02, 2019 06:02PM |
Re: Steps per mm not updating with new Marlin Flash July 02, 2019 06:20PM |
dvanommen
Hi all, I'm swapping out the extruder on an FLSun i3 plus to a geared extruder. I'm having a problem with uploading new firmware - I'm using marlin 1.1.9 and flashing to an MKS Gen L V1.0 board. When I upload the firmware, the new steps per mm value I entered for the extruder doesn't get logged on the board. Other things will change (I changed the name of the printer, and the new name appears on the landing screen on the LCD), just not the steps/mm value.
I first noticed this when verifying the calibration (a 10 mm extrude command continued to yield only ~3mm movement after the new firmware), then verified it using M501 through Pronterface. Every time I upload the firmware, I check to make sure the value in the file shows 425.411 for E0, then after uploading, I launch Pronterface, and M501 shows the E0 steps/mm is still 150.
I've tried using different USB ports, different USB cables, restarting the printer, my computer, Arduino IDE, etc. All to no avail. I even used a different copy of the Marlin firmware I had saved in a different location on my machine.
I'm lost. Any ideas?
Re: Steps per mm not updating with new Marlin Flash July 02, 2019 06:27PM |
Re: Steps per mm not updating with new Marlin Flash July 03, 2019 09:29AM |
Re: Steps per mm not updating with new Marlin Flash July 04, 2019 05:14AM |
Re: Steps per mm not updating with new Marlin Flash September 16, 2020 06:17PM |
Re: Steps per mm not updating with new Marlin Flash October 28, 2022 12:25AM |
Re: Steps per mm not updating with new Marlin Flash October 28, 2022 12:36AM |
Admin Registered: 13 years ago Posts: 7,004 |
Re: Steps per mm not updating with new Marlin Flash October 29, 2022 09:27AM |
Re: Steps per mm not updating with new Marlin Flash October 29, 2022 09:50AM |
