Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 08, 2008 08:08AM |
Re: Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 08, 2008 08:33AM |
Admin Registered: 19 years ago Posts: 1,915 |
Re: Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 09, 2008 09:02AM |
), the silicone tubing eased itself off the GM3 output shaft. I suspect this is due to the fact that only a tiny part of the output shaft makes it through the support (that is, the shaft is only a little bit longer than the support is thick, and it goes through the thickness of the support, so only a little bit sticks out). The silicone tubing goes over the entirety of the shaft, as the hole is big enough for that, but the zip-tie that tightens the tubing onto the shaft is too big for the hole, so it has to sit outside on the small part of the shaft-tubing interface, giving it a crappy grip, which makes the tubing fall off after a short while.
Re: Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 09, 2008 12:48PM |
Re: Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 10, 2008 04:26PM |
Re: Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 11, 2008 03:29AM |
Admin Registered: 18 years ago Posts: 14,170 |
Re: Problems with my [ply-] wooden McWire's GM3/RM2 powered leadscrews September 11, 2008 02:20PM |
