Firstly m going to presume you meant V4.2.2 not v4.4.2 as that doesn't exist as far as I can ascertain
You cannot connect this up without loosing the sdcard on the lcd. There are simply not enough pins.
So defining REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER is not a option as you cannot have a sdcard on the display that this define expects,
You need ti instead define CR10_STOCKDISPLAY and identical lcd type and encoder, but with no sdcard
Then you going to have to make a custom wiring harness form the 10 pin plug to the lcd and rotate the pins based on where the gnds are
* V4.2.2 LCD port
* BEEPER_PIN PC6 | 1 2 | PB2 BTN_ENC
* BTN_EN1 PB10 | 3 4 | PB11
* BTN_EN2 PB14 5 6 | PB13 LCD_PINS_D4
* LCD_PINS_RS PB12 | 7 8 | PB15 LCD_PINS_EN
* GND | 9 10 | 5V
to
/** Smart Adapter (c) RRD
* BEEPER_PIN | 1 2 | BTN_ENC | 1 2 |
* LCD_PINS_EN | 3 4 | LCD_PINS_RS BTN_EN1 | 3 4 |
* LCD_PINS_D4 5 6 | BTN_EN2 5 6 |
* | 7 8 | | 7 8 |
* (GND) | 9 10 | (5V) (GND) | 9 10 | --
* EXP1 EXP2
But Note:
Some lcds have the ports rotated 180 degrees. You need to check where the gnd pins actually are on your ports
Edited 3 time(s). Last edit at 04/15/2023 09:16AM by Dust.
