Hall Sensors
Posted by KDog
Hall Sensors
March 02, 2013 02:42AM
Hi All,
I got some hall effect end stops from Reprapdiscount and have installed one on my z-axis. I'm having trouble getting my z-axis to stop when the end stop is triggered. I can get the sensor to "see" the magnet (the led turns on) but the z-steppers don't turn off when it is triggered on a homing move. I've tried inverting the logic in my firmware (repetier) but the axis won't home at all then. Anybody have these working?
Thanks,
KDog
VDX
Re: Hall Sensors
March 02, 2013 03:55PM
... check for correct pin assignment ... and if the pin has correct pullup-settings ...
Viktor
Re: Hall Sensors
March 03, 2013 06:31PM
Thanks for the advice. Embarrassed to say....instead of connecting to the z-min, I had the endstop connected to the z-max....duh! Now works fine. The only change I had to make was to make the logic in the firmware "true" for the z-endsop.
Cheers,
KDog
