For all you RepRappers/Strappers in the UK, as promised I have put together a spreadsheet of all the parts required to go on (some of) the PCBs for the Generation 3 electronics.
The components are for the following Generation 3 boards:
* opto endstop v2.1 - need 3
* GM3 noise suppressor v1.0 for extruder motor - need 1
* temperature sensor v2.0 for thermistor - need 1
* stepper motor driver v2.3 - need 3
plus solder paste and tweezers.
I've not included other boards because I was able to buy the others as complete kits.
Here is a link to the spreadsheet on GoogleDocs:
Electronic components for Gen 3 PCBs
There are four sheets; the first contains all the parts required, the other three contain shopping lists for the relevant suppliers, including final costs. Ignore costings on the first sheet - incomplete and not up to date!
Other sheets show prices correct as at July 2009.
I hope this helps somebody at least!
Hazel
copycatbot.blogspot.com]
