Pronterface connected, but all motors doesn't move April 13, 2014 07:21PM |
Re: Pronterface connected, but all motors doesn't move April 14, 2014 06:40PM |
Re: Pronterface connected, but all motors doesn't move April 17, 2014 08:29AM |
3dkarma
Have you set the vref on the stepper drivers? If they are under-volted they won't move.
Have you set the steps per mm for each axis and the extruder in the firmware?
Re: Pronterface connected, but all motors doesn't move April 17, 2014 07:14PM |
Re: Pronterface connected, but all motors doesn't move April 21, 2014 11:41AM |
urbanzakapa
3dkarma
I have set the value for each axis and extruder but I'm not sure about the vref on the stepper drivers. How can I set it up?
Re: Pronterface connected, but all motors doesn't move April 21, 2014 05:13PM |
waitaki
Make sure you have all the jumpers fitted under the driver chips.
To set the voltage of each of the stepper drivers put one test lead on the negative input of the power connector and touch the other lead in the centre of the tiny potentiometer on the driver board. Set it to around 0.4v initially, You could sharpen a wooden toothpick or something to make a flat blade to adjust it.
Re: Pronterface connected, but all motors doesn't move April 21, 2014 06:19PM |
Re: Pronterface connected, but all motors doesn't move April 21, 2014 07:37PM |
urbanzakapa
waitaki
I have set the Vref, and already connect it to the pronterface, but when I click the button to make it move, it doesn't move. Do you think there are any problems with the calibration.h in the arduino codes?
Re: Pronterface connected, but all motors doesn't move April 29, 2014 09:30AM |
waitaki
urbanzakapa
waitaki
You didn't say whether you had fitted the jumpers under the driver boards?
Re: Pronterface connected, but all motors doesn't move April 30, 2014 04:38AM |
Re: Pronterface connected, but all motors doesn't move April 30, 2014 06:17AM |
waitaki
Yes, 3 for each motor driver for 1/16 microstepping. If you have stepstick drivers, set them to 0.8v and see how that goes.
What's the current situation with the printer?
Re: Pronterface connected, but all motors doesn't move April 30, 2014 06:35AM |
Admin Registered: 13 years ago Posts: 7,034 |
Re: Pronterface connected, but all motors doesn't move May 01, 2014 04:12PM |
